SOLVED Headphone Jack Prob
Okay, so, I just updated the kext to the latest version hearing some fixes on AMD HDA controller, and now it works just fine, OMG! Thank you for your support, I will also keep supporting you on ur yt channel!
You may close this thread :)
Just do help me with amdfriend there I need adobe reader working :(, what should i do if i have nootedred :-(
You should always consider using the latest kext unless there is a specific reason to use old version. Glad its fixed now!
Off-topic. Continue the discussion in the original thread!
NCC74656
