bluetooth headphone connection issue Big Sur
amirsss
Asus Z490m
Intel core i7 10700k
Nvidia GTX 1080 TI
11.0.x
Hello
I have a USB Bluetooth dongle (Asus BT400). I installed it on Big Sur without any kext, and it works. but when I want to connect my headphone, most of the time it says connect, but my device is still in pairing mode, but sometimes it will connect and sometimes show connect, and after a sec, it shows disconnect. I tried it with kext (BrcmBluetoothInjector+BrcmFirmwareData+BrcmPatchRAM3), but there was no difference, so I removed the kexts.
My device is
Monster Clarity HD On-Ear Sound Isolating Wireless Headphones​
and successfully connected through Windows.
Any help would be appreciated.
Hello
My device is
Remove those kexts and enable ExtendBTFeatureFlags and then check.
Actually I have done it but not help.apparently it acts like that when i used headphones...thanks
Attach your EFI to check.
Doud
