Hello, please help me understand one issue Sonoma 14.7.4
gurin
mashinist mr9a-pro-max
xeon e5-2680 v4
amd rx 580 GME
15.x
OSX is installed on a mini PC S200 eglobal.
i7-8750h UHD 630 16 Gb ram 1Tb SSD Samsung EVO 970+ 1Gb Lan RT8111 Wi-Fi BCM94360CS2
Everything works fine.
But there is one question that worries me.
In the settings, the Battery item appeared, although on Ventura it was normal (Power saving).
I am attaching a screenshot and the EFI folder.
Maybe someone will have some thoughts. Please do not scold me too much, I am a newbie in the OC, just getting used to it. I am grateful in advance for any information.
Sorry for bad English, used google translate.
  • EFI.zip
    EFI.zip
The battery disappeared or appeared?
The battery appeared.
I don't have a battery, it shouldn't be in the settings.
That's really surprising. Attach IOReg to check!
Hi!
This is definitely a surprise! I've already broken my whole head!:)
  • Macmini.zip
    Macmini.zip
Hi!
As expected, the ADP1 is loading which causes AppleACPIAdapter to load. Check for the SSDT in your EFI or any related kext. If there's none, then simply disable this device from loading and that should do the trick!
Thank you so much for the information! I've been experimenting with SSDT, but the situation doesn't change. If possible, please look at my EFI folder, it is attached above. Please tell us in more detail how and how to prohibit the download of ADP1, I will be very grateful to you!
Provide PR Files.
Do you mean this?
[Generate Proper Problem Reporting Files]​
If so, please forgive me, I have not found a tool with which to create such files. There is something similar on the tonimak86 resource, but I couldn't download the archive with the script. Please kindly provide a link to the appropriate tool.
Do you mean this?
PR Files are Problem Reporting Files. For more information, read the FAQ thread below:
NazranSami3
