That's because the App is no longer beta and the command would be changed:hi
sudo: /Applications/Install macOS Ventura beta.app/Contents/Resources/createinstallmedia: command not found
cause this folder "Install macOS Ventura" not existe
sudo /Applications/Install\ macOS\ Ventura.app/Contents/Resources/createinstallmedia --volume /Volumes/USB
