Can I install macOS on my laptop? And dual boot macOS and Windows 11?
ThatOneGuyUnknow
Motherboard: HP 8C30 Laptop Model: Victus by HP Gaming Laptop 15-fb1xxx
AMD Ryzen 5 7535H (Code Name: Rembrandt)
Nvidia GeForce RTX 2050
Hello, I'm new to Hackintosh and I have some questions about installing macOS and dual-booting macOS with Windows 11.
**Question #1:** Can my laptop run macOS? (Any version works for me.) Here are the specifications of my laptop:
**CPU:** AMD Ryzen 5 7535H (Code Name: Rembrandt)
**Motherboard:** HP 8C30
**Graphics:** Nvidia GeForce RTX 2050
(I will include screenshots of the specifications if I missed any information.)
**Question #2:** If my laptop can run and install macOS, which version can I install? How can I install macOS on my laptop?
**Question #3:** Am I able to dual-boot macOS and Windows 11?
Solution
Yes, it can.
You can install upto macOS Sequoia.
Yes, you can. As there is no information regarding the disks, there is no confirmation for the compatibility under macOS.
In addition, please note that you'll not be able to utilize the graphics as the CPU you have isn't compatible with NootedRed at the moment. The maximum supported CPU with Graphics is 7x30 series.
Yes, it can.
Solution
Okay, what would it look like if I could dual-boot but couldn't utilize the graphics? Or would it just run using the iGPU? or iCPU? (I don't know if there is a iCPU)
And how can I install macOS and dual-boot?
Yes, it can.
Okay, what would it look like if I could dual-boot but couldn't utilize the graphics? Or would it just run using the iGPU? or iCPU? (I don't know if there is a iCPU? And sorry I forgot to hit reply)
Yes, it can.
And how can I install macOS and dual-boot? (And sorry I forgot to hit reply)
The IGPU model you have is not supported. There is nothing such as iCPU.
On macOS side, it would be extreme laggy, frequent server crashes, some App won't even work.
WYLDE983
