Installing and Dual Booting macOS Sequoia
ThatOneGuyUnknow
Motherboard: HP 8C30 Laptop Model: Victus by HP Gaming Laptop 15-fb1xxx
AMD Ryzen 5 7535H (Code Name: Rembrandt)
Nvidia GeForce RTX 2050
Hello, I'm new to Hackintosh I was told by EliteMacx86 that I could do "macOS Sequoia" (Thread Link: https://elitemacx86.com/threads/can...ptop-and-dual-boot-macos-and-windows-11.2199/) and I never response back so I think it's resolved I don't know but also I want to dual-boot so I can keep Windows and have macOS but I don't want any issues (Yes I heard that they might be some issues when using and installing macOS) I have been trying following this Opencore guide (Link: https://dortania.github.io/OpenCore-Install-Guide/) instead it didn't work so I come here to see if there was any other way to install macOS again I was told by EliteMacx86 that I could "install macOS" but they did say that there was going to be issued with the graphics because "In addition, please note that you'll not be able to utilize the graphics as the CPU you have isn't compatible with NootedRed at the moment. The maximum supported CPU with Graphics is 7x30 series." and I don't what to do for graphics I don't if I could use iGPU or iCPU (I don't know if there is a iCPU?) but as long it run smoothly and install smoothly I will be happy and ok so if someone can help me I will be satisfied. Thank you!
In short, the Graphics will NOT work as the model you have is unsupported. Without a Graphics acceleration, macOS is pretty unusable. The performance would be similar to VMware, VirtualBox, Hyper-V.
usernel
