SOLVED How to Fix WiFi detected but not working on macOS
x0r
  1. Mac Pro
@EliteMacx86
A similar situation described in your post How to Fix WiFi detected but not working on macOS
Hackintosh Diagnostic Summary
User: x0r
Board Model: Mac Pro
Board Model Identifier: MacPro7,1
Bootloader: OpenCore
macOS Version: 14.7.2
Build: 23H311
Hardware Information Summary:
MB: x670e Aorus MAster(rev1.0)
CPU: AMD Ryzen 9 7900X 12-Core Processor
GPU: AMD Radeon RX 6900 XT 16 GB
This information is a Linux OS log
* Network controller [0280]: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] [8086:2725] (rev 1a)
* Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz [8086:0024]
* Intel AX210 WiFi Card Full Hardware Definition
* Device ID: [8086:2725]
* Subsystem: [8086:0024]
* PCIe 4.0 x1 Interface
* WiFi 6E Support (2.4GHz, 5GHz, 6GHz)
* Bluetooth 5.3
Solved
I'll add solution later
Screenshot 2025-01-13 at 8.39.13 AM.png Screenshot 2025-01-13 at 8.36.26 AM.png Screenshot 2025-01-13 at 8.36.17 AM.png
👇 It was like this :mad:
Screenshot 2024-12-26 at 9.49.18 AM.png Screenshot 2024-12-26 at 9.48.46 AM.png Screenshot 2024-12-26 at 9.49.00 AM.png Screenshot 2024-12-26 at 9.49.52 AM.png Screenshot 2024-12-26 at 9.52.57 AM.png Screenshot 2024-12-27 at 2.32.53 AM.png Screenshot 2024-12-27 at 10.41.56 AM.png Screenshot 2024-12-27 at 10.42.59 AM.png Screenshot 2024-12-31 at 3.49.08 AM.png
As per your config.plist, it seems like you're using itlwm.kext which requires Heliport to work.
What? Did you tried the guide? There is no reason to post with 0 content.
@EliteMacx86 currently EFI folder
I've tried different options but it doesn't help.
WiFi doesn't work, Bluetooth works.
The WiFi adapter does not initialize properly and is not displayed for Hackintool.
With another EFI driver, displays correctly AX210/AX1675* 2x2, currently as this WIFI 6 AX210/211/411 160 MHz. But in both cases the wifi doesn't work, which is frustrating.
This is currently config.plist in pinned messages.
Also these are some of the SSDTs.dsl that were used, IOPowerManagement flags change, but the WiFi card are not displayed and the bluetooth stops working.I do not inderstanding and proficiency in a Domain-Specific Language (DSL).SSDTs data written by AI assistant.
View attachment 8885View attachment 8886View attachment 8887
The question is are you using Heliport or not?
adamnor206
