Reactions: Chucksmmadu
Yep ☺ it worked... but i still have battery problem 😑 I'm considering a battery replacement and aftet which i do my patches again! Did you check if it's necessary to uncomment the code i pasted earlier in my dsdt 🤓
Not yet. First i suggest you to check with Windows and linux. If the problem persists, update here.
Let me explain the behaviour properly. When using mac os, my battery last a little bit longer than it used to before i added cpufriend and cpufriendataprovider but the issues are as follows for a very long time now, my battery haven't charged beyond 60% and my battery full capacity is 3640mah but its always about 998mah, 1144mah or 2000+mah in rare cases . I check using system preference and battery monitor and whats weird is that mac os sees only two cores out of the four cores my processor has(I checked using isats menu). As for windows and pop os the behaviour is the same. Battey it lasts longer than mac os and Pop! os in windows 10 but it still never charges beyond 60% and most cases it will say plugged, not charging.
Thanks for the explanation. Did you tried to charge the battery in off state? Have you tried to monitor the battery backup time?
The battery's behavior is still the same even when i turn it off. Once it gets to a certain percentage, it stops charging and shows the white light instead of the charging light. The only thing i haven't tried is removing the battery as it's built in 🙂 bit what do you mean by battery backup time 🤥
This sounds quite weird.
Try disconnecting and then connect to check if there's any change.
Meaning for how long the battery lasts.
In windows it can last up to one and half an hour or less but in macOS it struggles to last an hour... Because i undervolted (with voltageshift and I'm using cpufriend yo get the cpu below 0.8mhz at idle) if not it doesn't last up to 50mins of use
So, the battery is not charging.
wyattst99
