How to Fix Drive not detected during macOS Installation
This guide covers fixing Drives not detected in Disk Utility during macOS installation.
When installing macOS, at Disk Utility, you might have noticed that the target drive (either SATA/M.2/NVMe) drives does not appear. This is because macOS cannot find the drives connected to the SATA Controller.
Compatibility
On macOS, not every Storage Controller is supported. Refer to the thread linked below for more information on Storage compatibility.
elitemacx86.com
STEP 1: Enable AHCI
The first step is to enable AHCI Controller from the BIOS/UEFI.
1. Boot to BIOS/UEFI.
2. Find SATA Controller Mode and set it to AHCI
3. Save Changes and Exit
STEP 2: Enable Unsupported SATA Controller
The next step is to enable an unsupported SATA Controller so that macOS can find the controller and as a result, macOS will be able to communicate with the disk. To enable an unsupported SATA Controller, follow the steps below.
1. Download CtlnaAHCIPort from the downloads section of this forum.
For Clover:
If you're using Clover, copy the kext to EFI/Clover/Kext/Others
For OpenCore:
If you're using OpenCore, copy the kext to EFI/OC/Kexts. You'll also need to add the kext entry in the Kernel section of your config.plist.
3. Save your config.plist
Now, you should be able to see the drives during installation.
Disable Intel RST Premium
Disable Intel Optane
Make sure you're not using RAID/RST and unsupported SSD such as Intel Optane.
Compatibility
Storage Compatibility for macOS
Storage Compatibility for macOS Intel AHCI and RAID Controllers VendorChipset SeriesVEN ID:EV IDSupport Kext Intel5 Series Chipset8086:3b29 8086:3b22 8086:3b2f Intel5 Series/3400 Series Chipset SATA RAID Controller8086,3b25 8086,3b2C Intel6 Series Chipset8086:1c02 8086:1c03 Intel6...
elitemacx86.com
STEP 1: Enable AHCI
For Clover:
For OpenCore:
