SOLVED Open core and Monterey Installation problems
ok i followed the guide. my motherboard does not have hdmi but only vga, how do i insert it in the properties device of the igpu card?
There you go. VGA isn't supported.
could you still tell me the problem of the errors that I attached in the image? through a guide I managed to insert the vga as displayport and it works but I don't understand these loop errors that come out related to bluethootd and language
Which image?
Se si utilizza un display non supportato, nonostante l'EFI sia compilato correttamente, il display non si accenderà mai e si bloccherà su diverse linee casuali.
e cosa posso fare se il mio principale non ha HDMI? Il mio monitor ha HDMI ma il mio principale no. Come posso risolvere questo problema?
English only!
sorry.
and what can i do if my main one doesn't have HDMI? My monitor has HDMI but my main one doesn't. How can i fix this?
sorry.
Simply. use the monitor that has HDMI and complete the installation with that.
mohthearrow
