Dell Optiplex 7470 UHD 630 Pink screen or Black screen
Ahmed Ali Shah
hp868b
Comet Lake i7 10th Gen
Intel UHD
Hello sir,
I have Dell Optiplex 7470 All-In-One, with 9th gen Coffee lake refresh CPU. I have followed dortania's guide but my screen becomes black. Then I saw that adding boot arg -igfxmod=pikera will solve it but no chance. Then I tried hackintool, it resloves the problem of graphic accellerattion but screen is Pink. I have also visited these sites
https://dortania.github.io/OpenCore-Post-Install/gpu-patching/intel-patching/connector.html
but still no results. Sometimes it goes black screen and sometimes Pink. Please help me resolve this issue. Thanks
Hello sir,
No PR Files attached!
the cong file gives me black screen and config0 file give pink screen but with full accelleration
ioreg file of pink screen with full accelleration
Check your actual display connector using:
Patch the connectors using:
@Ahmed Ali Shah Your AIO has HDMI connector for the built-in display. You'll need to change the con2 from 00040000 to 00080000 and the display should be normal.
Kindly mention exactly what to write in busid, type...etc. Is that 00080000 is a busid?
Also please mention what boot args to apply in case of black screen?
kod_mic
