Thanks, that the new efi and doesnt work...
What exactly doesn't work? The system fails to boot or the Graphics doesn't work?
Also, seems like you did not understand well and the Quirks are not configured properly.
Enable the following:
AvoidRuntimeDegrag
EnableSafeModeSlide
ProvideCustomSlide
SetupVirtualMap
You should be able to boot into macOS
-igfxvesa is still in your config.plist you have to delete that
and what error? check BIOS DVMT =64MB or 128MB
The -igfxvesa is remove in my efi.
My dvmt is already at 64mb
And the error is in the attached file (sorry for 2 pictures i have a WS)
AvoidRuntimeDegrag
EnableSafeModeSlide
ProvideCustomSlide
SetupVirtualMap
I have change And the new error is
Are you using only IGPU or is there any Graphics Card installed?
I have a MSI GeForce GTX 1660 Super.
But i know it’s impossible with macOS.
So i want use IGPU on mac and my 1660 on Windows.
Then, you need to disable the GTX 1660 Super using the boot arg or via SSDT. You can use -wegnoegpu and check if you can boot. If not, add -igfxvesa and do the framebuffer patching.
Same problem. I put -wegnoegpu and I have the error at the beginning of loading (photo 1). And when I put the Quirks of the video + those that you told me to put earlier, the loading is longer but still an error (photo 2). If I use -igfxvesa, which framebuffer patch to put?
You must enable the Quirks which was mentioned in post #11.
In addition, you'll need to use -wegnoegpu to disable the GTX 1660Ti and -igfxvesa to disable the IGPU Graphics as you have not patched the framebuffer yet. Seems like the bootarg is being put wrong way. Attach the EFI with the Quirks+-wegnoegpu+-igfxvesa. Also, are you sure you're booting from the correct EFI?
Lastly, you must disable Resizable BAR from BIOS. Probably, that's what preventing the system to boot into macOS.
Sorry for the late message,
I corrected the Quirks and I share the error and the efi with you.Yes I boot on the correct EFI.
I havent resize bar in my MB…
  • EFI.zip
    EFI.zip
I do change my framebuffer ?
raymondleung416
