 - Jul 27, 2024
 - MSI Z390 Tomahawk
 - i5-9600k
 - Intel UHD 630
 - 14.x
Hello,
I have a problem on my Hackintosh under macOS Sonoma, I currently have 16MB of video memory, the acceleration does not start.
I use the classic EFI which worked for the installation, I looked on the WhateverGreen GitHub, I use the right framebuffer, AAPL and device-id and nothing works, even sometimes I have an error.
I saw on the GitHub that you have to use the KabyLake device-id, and same problem, it does not work..
My computer:
MB: MSI Z390 Tomahawk
CPU: i5-9600k (CoffeeLake)
GPU: Intel UHD Graphics 630
I'll give you the mistakes I may have had.
I am really exhausted looking for a lot of solutions on google, on youtube and nothing works..
Thanks !!
My computer:
Thanks !!
