Zippy
MSI Z390 Tomahawk
i5-9600k
Intel UHD 630
Hello,
I have a problem on my Hackintosh under macOS Sonoma, I currently have 16MB of video memory, the acceleration does not start.
I use the classic EFI which worked for the installation, I looked on the WhateverGreen GitHub, I use the right framebuffer, AAPL and device-id and nothing works, even sometimes I have an error.
I saw on the GitHub that you have to use the KabyLake device-id, and same problem, it does not work..
My computer:
MB: MSI Z390 Tomahawk
CPU: i5-9600k (CoffeeLake)
GPU: Intel UHD Graphics 630
I'll give you the mistakes I may have had.
I am really exhausted looking for a lot of solutions on google, on youtube and nothing works..
Thanks !!
Hello,
My computer:
Thanks !!
Attach the EFI you're using!
Thanks, that the new efi and doesnt work...
you need to add in your Device Properties for your graphics in:
<key>DeviceProperties</key>
        <dict>
            <key>Add</key>
            <dict/>
            <key>Delete</key>
            <dict/>
        </dict>
and you need to remove -igfxvesa boot argument
        <dict>
            <key>Add</key>
            <dict/>
            <key>Delete</key>
            <dict/>
        </dict>
i change this, check. But i have error in the kernel And dont start
-igfxvesa is still in your config.plist you have to delete that
and what error? check BIOS DVMT =64MB or 128MB
alvarg82
