loading bar block
From BIOS, set DVMT to 64MB. Remove -igfxvesa boot arg. Reset NVRAM and then check
I just tried following your suggestion but it doesn't work. It always shows those errors and if I don't forcefully restart it it doesn't do anything and stays stuck
Attach the EFI you're using. Also, it seems like you have Windows on the same drive. Is that correct?
I am sending you the efi folder used and I confirm that on the same hard disk I have Windows in one partition and I am trying to install MacOS on another partition with the intention of creating a dualboot
is there a way to solve?
this is the EFI folder that I used
scoobypetey
