loading bar block
the bios has remained unchanged so the photos I sent you are the last ones. Instead I'll send you the EFI folder
Disable IgnoreInvalidFlexRatio Quirk. It's required only on Broadwell and older systems.
Also, remove the Load Early option for OpenCanopy.efi.
nothing... always the same error
-igfxvesa is already present in the boot args. In fact the problem is not the installation program which I can reach without problems, but as you can see in the video when I go to select the new partition created by the installation program and therefore I want to proceed with the first installation of the operating system (choice language, choice wifi etc) it doesn't let me get there because it gives me that warning
No, the video you attached, the installer boots. But before you can reach the installation stage, it throws Kernel Panic.
Need to clear facts. Its not warning, its Kernel Panic. If Kernel panic happens during booting the installer, you cannot reach the installation stage. The first installation screen is the language or Recovery Menu.
ok to avoid misunderstandings I will send you the complete installation video. In the last part of the video the computer was forcibly restarted by me because otherwise it would always remain stuck with the same error. However, all the crashes you see eventually repeat themselves alternating when the PC is restarted and you try to start the Hackintosh partition.
PS: some parts of the video have been sped up
From BIOS, set DVMT to 64MB. Remove -igfxvesa boot arg. Reset NVRAM and then check
xxxxxxxxxx
