Random reboots while loading the system
I don't know if using WhateverGreen + Spoof for the 6900 XTXH card has any advantages over NootRX. Under normal system use, there's no difference—the graphics card works fine in both cases. However, when upgrading MacOS (for example, I upgraded from Tahoe Beta 5 to Beta 6 today), the WhateverGreen + Spoof combination doesn't handle it. It can't properly launch the GUI during the update. With NootRX, the update proceeds without any issues.
Did an upgrade recently and it works absolutely fine. Until you make the changes as listed above, you'll be in loop in either of the macOS version. So, better you make those changes to enjoy the system :)
kcbednar
