I've checked everything. Everything is on auto and connects properly.
Can you describe the original issue you are having?
I'm connected to my UDM-SE trough USW Aggregation Switch to my machine. I have Intel X520-DA2 HP 560+. Connected with ubiquiti SFP. Everything
Okay everything works now :) I'm Getting 1.1 GB/s from and to server.
Glad to hear. What was causing the issue?
Really dunno. Just reconnected everything one more time and magically started to work.
Maybe loose cable or something like that!
Now. I have a problem with Thundebolt Hotplug :C. I'm on 14.5 and it's not working
This thread is dedicated to NIC compatibility. Please create a separate thread.
Fixed it already :) Security Level option was bugged. In bios it showed SL0 but really was set to SL1. Redid it and everything works.
ploukop
