Stuck on ApplePS2Controller Catalina ( ASUS ExpertBook P3540FA )
My comment is below somehow:
The Settings looks fine. Try different USB and different port.
I tried using different USB, change the USB port, re-downloaded the image, remove -igfxvesa from the boot-args and add alcid=1 but the kernel panic is still there.
Keep -igfxvesa enabled and then check.
I did but the kernel panic is still there. What's the problem even come from? Dead end or smth or maybe my hardware cant install Hackintosh, idk.
Your hardware is compatible. Will do final check in a while.
What's the exact Laptop model number?
xxxxxxxxxx
