Stuck on ApplePS2Controller Catalina ( ASUS ExpertBook P3540FA )
Could you tell me the kext and drivers right order cuz i'm so idk about the right order.
Its mentioned in the installation guide!
Edit: And also thanks for telling me, i'm gonna update my bios.
Try to make the changes first and then check. ASUS Notebooks have problems with the updated BIOS version.
Also, try to add CPUTscSync.kext
After i make the changes, i encountered a kernel panics somehow. I did update the bios make change the order ( idk if the is right ) below is my efi folder:
Probably, it's due to the double kext injection of VoodooInput. Disable all the VoodooI2C kexts and then check
I disable all the VoodooI2C kext and kernel panic is still there. Is there any way to disable the auto-reboot when encountered kernel panic because it's annoying when the kernel panic happens and reboot right after that and i can take a picture of that.
Remove - from debug=0x100 and then check.
Thanks. I was able to take the picture. Here it's:
Well, this is right after the KP. Can you provide a uncompressed video?
You mean a full video? I can do that
Yes, do that. Upload the video on Google Drive or WeTransfer. Do NOT use any other app for recording video. The verbose must be clear enough to read. Use native Camera app.
Filopateer Amir
