MacOS stuck on AppleACPICPU on my PC
I tried installing mac via online method and it seems to not be stuck on AppleACPICPU anymore
but a new issue came up, it takes me to the apple logo and its stuck there for a while with no progress bar then it shows a black screen and then it restarts my pc and i see my windows screen @EliteMacx86
i made some changed to my EFI folder
turns out i had whatevergreen.kext in my Kexts folder but it wasnt there in the config.plist file
so i added that and i added AMDRyzenCPUPowerManagement.kext and SMCAMDProcessor.kext
and i have added opencanopy.efi for a better UI
the issue has still not been fixed.
You should NOT use WEG and NootedRed together.
The result is same. This is just without verbose.
kcbednar
