Sorry i attatched only kext according to what you told me to do previously... 😐 here is everything.
Still incomplete PR files. No kextcache output attached. You must attach all the files in a single .zip
Also, you must be noticing the performance now. A lot better!
  • Love
Reactions: Chucksmmadu
Yes the performance is better than it was! ✌... Here's everything.
That's the result when you follow the guide.
The kextcache command is
sudo kextcache -i/
Why are you using old method for fixing Backlight?
Remove AppleBacklightInjector from L/E
Remove the KextToPatch entry for the same from your config.plist
Remove FakeSMC sensors kexts. Those are not needed.
Reply with new files.
OK Sir... Done!!!
OK Sir... Done!!!
Now, it's perfect. Remove the SSDT-PNLF from ACPI/patched.
Now, it's time to do the DSDT and SSDT patching. I recommend you to do a Full patched DSDT + SSDTs.
Follow the guide form the first page. Make sure to extract fresh files and then proceed with.
Make sure to remember what patches you've applied.
After patching it, follow the Backlight guide:
Make sure you follow the Method 2 from the guide.
Once all is done, boot using the updated files.
Reply with the updated files.
uhmm!! On the subject of dsdt, Plese help me confirm if/not this is the right patch for my dsdt (Battery). what do ido with the SSDTs i mean what patch do i apply in them?
Yes, use the "#battery_HP-Pavilion-n012tx.txt" patch for Battery status.
For the SSDTs, you need to apply SSDTs patches. Read the guide.
Read the post how to attach your DSDT files.
ok THANKS i used the "battery_HP-Pavilion-n012tx.txt" patch I've got bettery meter working but my battery of ~3640mah is showing as 1330-990mah. Does it really mean i need to replace my battery 🤔...
No files attached. Did you patched your DSDT fully? With all the patches? Does the battery meter works as expected? Does it asks or notifies you to replace the battery?
Oh sorry i will attach my dsdt in my next post... Yeah it shows the replace battery notification in the battery status panel i applied : rtc, smbus, hpet, and battery patch🙂
fierofree
