I'm using a hard drive that's it my system even windows takes at least one minute to boot! And that's the file i used to boot sadly... By January, i will be buying an ssd i can't afford one now 😔
Ah ok. In which post you submitted the PR files?
I submitted it previously but here you go once more.
config.plist file is corrupted.
Some drivers are missing from the drivers folder. Make sure you reinstall Clover as per the guide.
No kexts present.
Follow the guide and fix the issues
Reactions: Chucksmmadu
I successfully booted after adding the kext. So for now, no battery icon, no Trackpad, no sound and no brightness slider in preferences panel... Here is the new P.R file... i included screenshot clover installation. i added them in the zip file too.
Still, you did NOT followed the guide carefully. Is there any issue in reading and understanding the guides?
Do the following changes
Install Datahub and AudioDxe driver.
Delete the NVIDIA and AMD properties from the config.plist/Devices
Uncheck Inject ATI and Inject Nvidia from Graphics tab in config.plist
Generate a new SMBIOS of MacBookPro14,1
Set Inject Kexts to Yes and enable Inject System ID in System Parameters
Delete the folders except Other from Clover/kexts
Reply with new PR files.
Sorry i have been having troubles with this i will upload a new PR file after this 😔
OK Following the guides at the end of the... https://www.elitemacx86.com/threads...ller-on-laptops-using-clover-uefi-legacy.177/ , so far i have power management working (I checked using intel power gadget and ioreg), sensors showing and maybe working (i checked using hwsensors app), brigtnesss slider in preference panel, I also got trackpad working (I'm using appleps2smarttouchpad.kext since my trackpad is ELAN) but it doesn't show in preferences pane. I didn't touch my dsdt as i haven't succeeded in my previous attempts to patch it. And i'm yet to do anything related to audio. Thank you for bringing me this far!!! :)
Incomplete PR files attached.
JohnnyMortsel
