And i just did the brightness key patch here is the latest patched dsdt file.
Seems perfect. Your Brightness Hotkeys should be working.
Reactions: Chucksmmadu
brightness hotkeys are Working 100% 👐
Need some tweaks.
Perfect!
Here are some issues
config.plist is modified. Change it back to original one.
No Audio injection. Read here:
ok i will do so right
away and upload files
I have replaced my config with the stock one. I unchecked inject nvidia and ati as you asked me to do previosly, then removed the nvidia and ati entries in devices section, enabled the change ec0 to ec and the theme name. What files should i submit? I can't use the pr file generator as my wifi isn't working yet.
What's the issue with your WiFi? After making changes to your config.plist, the WiFi doesn't works?
For dw1820a to work, i will have to inject some properties in pci for airport, and add two boot Args (brcmfx-driver=1 and brcmfx-country=#a) i didn't do it so that i don't mess with the config yet!
You can add those. Not an issue.
Ok i'm on it and would upload files ASAP! ✌
kaikkmi
