Limitations
Desktop APUs
XVIII. Lynx (Liano)
  • Max Native Support: 13.x
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Virgo (Trinity)
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
HD7660D
XVIII. Richland
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
8570D
8650D
8670D
XVIII. Kabini
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Kaveri and Godavari
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Carrizo
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Bristol Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Raven Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Picasso
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
Hello there i have been trying to install mac on my ryzen 7 5700g with no luck, is it possible, could some one please help me, i new here
What does not work?
Imnot sure, but it always give basically the same message, that the os version is not compatible with my board or something along those lines, and i have tried with almost every version from big sur, and doble checked the config.plist and the kexts
This is a compatibility related thread. Please create a separate thread for the issues you have.
Reactions: Alexandeer
Very unlikely.
Hello there, idk anything about virtualization on this level, and proxmox and everything, only used hackintosh back in the day with those parts that were "easy" to find kexts and tutorials, and that was long ago. Can you point me to material where I can study how it works and why Raphael specially is very unlikely to get support?
Well, your profile indicates you have an Intel hardware.
Sorry, it's been a while since I last logged in here, I'll update it, my igpu is a Raphael. I'll update it.
Not an issue :)
ploukop
