ASUS PRIME Z690M-PLUS D4 - i9 12900KF - 128GB RAM - AMD RX 5700XT - Thunderbolt HotPlug - OpenCore
Hello
ASUS PRIME Z690M-PLUS D4 Build featuring Latest Intel Core i9 12900KF, Thunderbolt 3 and AMD RX 5700 XT using OpenCore. This Build is especially for Music Production offering multiple Thunderbolt ports supporting daisy chain, Cinema Display for a robust workflow. This guide can be used as a reference for any 600 series Motherboard with very few changes.
Components
ComponentModel Number
MotherboardASUS PRIME Z690M-PLUS D4
ProcessorIntel Core i9-12900KF
RAMPatriot Viper Steel 3200MHz 1288GB DDR4 RAM (4x32GB)
GraphicsPowerColor AMD RX 5700XT 8GB
SSDTeam Force 4TB PCIe NVMe SSD
AudioRealtek ALC897
Display
EthernetIntel I219-V
Wireless/BluetoothFenvi BCM94360CD
ThunderboltGIGABYTE GC-Titan Ridge v2.0
Already Owned
Fractal Design Define 7XL (CC-9011078-WW)
LG 32" Full HD IPS Monitor with HDMI, and Display Port (LG 22MP58VQ-P)
Antec HCG Gold 750W Power Supply
Dell KM636 Wireless Keyboard & Mouse Combo
Comments
The Build
As the new 600 series Motherboard is out, I decided to test it and check the performance on a Hack. The idea of this build is to utilize Thunderbolt and use it for production.
Due to the easy availability of Z690 and the number of NVMe slots that were needed, the ultimate choice was ASUS Z690M-PLUS D4. It's a mATX motherboard offering support for 12th Gen. CPUs. PCIe 4.0 supports a faster data transfer rate. Along with all these, the motherboard supports 3x PCIe 4.0 NVMe and built-in WiFi.
On this Motherboard, the Audio Codec is not so great, offering ALC897. In addition, this Motherboard only offers 4xSATA 6.0Gb/s ports. An addition of 2.5Gb/s LAN would make it awesome but considering the budget, it's still a good go as these two were not the needs for this build.
Summary
FeaturesStatus
GraphicsYES
Built-in AudioYES
DP/HDMIYES
DP/HDMI AudioYES
EthernetYES
WiFi/BTYES
AirDropYES
HandoffYES
Thunderbolt 3YES, with full HotPlug
Thunderbolt DockYES, with full HotPlug
eGPUYES, with full HotPlug
Power ManagementYES
App StoreYES
iMessageYES
FaceTimeYES
iCloudYES
USB 2.0, 3.0, 3.1 and USB Type-C PortsYES
Not working
Everything works like a charm.
Bootable Media Creation
2. Plug USB to your system.
4. Close Disk Utility.
5. Open Terminal and type:
6. Enter your password
  • At this point, the bootable USB can be only used to boot Mac only. In order to boot the computer using the USB, follow the steps below.
Preparing OpenCore Bootloader
DirectoriesDescription
DocsContains documentation, change log, a sample config.plist, and ACPI Samples for OpenCore.
IA32Contains OpenCore EFI, 32-bit OpenCore Boot Loader.
UtilitiesContains several utilities.
X64Contains OpenCore EFI, 64-bit OpenCore Boot Loader.
Adding Required SSDTs
SSDT NameNotes
SSDT-EC-USBX
  • This SSDT fixes EC and USB Power.
  • This SSDT is required for proper USB Power.
SSDT-RTC0
  • This SSDT serves series RTC patch.
  • This SSDT is required for RTC compatibility.
SSDT-PMC
  • This SSDT is required for NVRAM support.
  • This SSDT is required for all 300 series motherboards except Z370.
  • This SSDT fixes NVRAM and can fix sleep/wake, restart/shut down issues.
  • This SSDT can also fix black screen after macOS finishes loading. This applies to IGPU, NVIDIA and AMD.
SSDT-PLUG-ALT
  • This SSDT enables Power Management function for Alder Lake CPUs.
  • This SSDT is required for proper CPU and GPU Power Management.
Adding Required Drivers
Driver NameRequiredNotes
OpenRuntime.efiYES
  • Runtime driver including several other drivers merged such as ApfsDriverLoader.
  • OpenRuntime.efi is a replacement for AptioMemoryFix.efi driver.
OpenHfsPlus.efiYES
  • Provides reading of HFS+ Volumes/drives in OpenCore Boot Picker.
OpenCanopy.efiOptional
  • Provides GUI functionality for OpenCore Boot screen.
  • This driver is required if you need GUI or theme for OpenCore.
AudioDxe.efiOptional
  • Provides Boot Chime support.
  • Only required if you want to use Boot Chime
2. From the EFI/OC directory, just keep the above drivers and delete rest of the drivers.
  • All the drivers can be found at: X64/EFI/OC/Drivers
Adding Required Kexts
Kext NameRequiredNotes
LiluYES
  • Provides arbitrary patching.
VirtualSMCYES
  • Emulates Apple hardware. VirtualSMC is a successor of FakeSMC.
  • This kext requires "Lilu.kext" to function.
WhateverGreenYES
  • Provides GPU patching on macOS.
AppleALCYES
  • Provides Audio support on macOS.
NVMeFixYES
  • Provides NVMe Power Management.
USBInjectAllYES
  • Enables USB ports for mapping USB ports further.
  • It's advised to map the USB ports during the post-install for a better USB speed, improved sleep/wake and hotplug.
XHCI-unsupportedYES
  • Enables Unsupported USB ports.
IntelMausiYES
  • Enables Intel Family onboard Ethernet Controller.
1. Download the above kexts.
Notes
  • Do not download the project files. The pre-built binaries/downloads are available in the README.md section. Make sure you read it carefully.
  • Use the kext from RELEASE folder and RELEASE.zip file.
  • Do not place unnecessary kexts here. It might prevent booting the installer.
  • Only use basic kexts which is required to boot off the installer. You can install the rest required kexts at the time of post-installation.
  • The VirtualSMC package includes Battery and Sensors plugins (SMCBatteryManager.kext, SMCDellSensors.kext, SMCLightSensor.kext, SMCProcessor.kext, and SMCSuperIO.kext). You do not need these kexts for booting the installer.
ACPI>Add
SSDT NameNotes
SSDT-RTC0
SSDT-EC-USBX
SSDT-PMC
SSDT-PLUG-ALT
  • This SSDT is required for a proper CPU and GPU Power Management.
ACPI>Patch
Table Signature*FindReplaceCommentEnabledNotes
DSDT5045475047465830Rename PEGP to GFX0 (Graphics)YES
  • Renames PEGP to GFX0 for a better power management.
  • This rename is required for implementing discrete GPU Power Management.
DSDT48454349494D4549Rename HECI to IMEI (PAVP)*YES
  • Renames HECI to IMEI for PAVP services.
  • This rename is required for implementing PAVP services.
  • This rename fixes iTunes/App Store Content Access problems and also enables Content playback.
DSDT4D45495F494D4549Rename MEI to IMEI (PAVP)*YES
  • Renames MEI to IMEI for PAVP services.
DSDT4844415348444546Rename HDAS to HDEF (Audio)YES
  • Renames HDAS to HDEF for Audio.
  • This rename is required for implementing Audio Function.
Booter>Quirks
QuirksValueNotes
AvoidRunTimeDefragYES
  • Fixes certain UEFI runtime services such as date time, NVRAM, power control, etc.
  • Apart from Apple and VMware, this quirk is required by rest of the firmwares.
  • It's recommended to "enable" this quirk.
DevirtualiseMmioYES
  • Remove runtime attribute from select MMIO regions.
  • This option reduces stolen memory footprint from the memory map by removing runtime bit for known memory regions.
EnableSafeModeSlideYES
  • Patch bootloader to have KASLR enabled in safe mode.
  • This quirk requires ProvideCustomSlide to be enabled.
  • This quirk can be helpful if you're unable to boot into safe mode.
ProvideCustomSlideYES
  • Provide custom KASLR slide on low memory.
  • This option forces macOS to use a pseudo random value among the available ones.
RebuildAppleMemoryMapYES
  • Generates Memory Map which is compatible with macOS.
  • Since several types of firmware come with incorrect memory protection tables, this quirk often comes paired with SyncRuntimePermissions.
SyncRuntimePermissionsYES
  • Update memory permissions for runtime environment.
  • The need for this quirk is indicated by early boot failures. Only firmware released after 2017 is typically affected.
ProvideMaxSlide0
  • Provide maximum KASLR slide when higher ones are unavailable.
Note:
  • The values which have been not discussed above will remain disabled.
DeviceProperties
This section is used for adding device properties. This includes PCI Devices information such as Graphics, Audio, WiFi, Ethernet and other controllers. No any changes are needed.
Kernel>Add
ArchBundlePath*ExecutablePathPlistPathEnabledNotes
AnyLilu.kext**Contents/MacOS/LiluContents/Info.plistYES
AnyVirtualSMC.kext**Contents/MacOS/VirtualSMCContents/Info.plistYES
  • VirtualSMC is a successor of FakeSMC.
AnyWhateverGreen.kext**Contents/MacOS/WhateverGreenContents/Info.plistYES
AnyAppleALC.kext**Contents/MacOS/AppleALCContents/Info.plistYES
  • Enables onboard/built-in Audio.
AnyUSBInjectAll.kext**Contents/MacOS/USBInjectAllContents/Info.plistYES
  • Enables USB ports.
  • It's advised to map the USB ports during the post-install for a better USB speed, improved and sleep/wake.
AnyXHCI-unsupported.kext**Contents/Info.plistYES
AnyIntelMausi.kext**Contents/Info.plistYES
Notes:
  • All the plugins must load after loading it's dependencies otherwise the kext will no longer function even when loaded in OS X/macOS.
  • The mandatory kexts must be loaded in sorted order as shown in the above table.
  • *Indicates BundlePath i.e. Name of the Kext
  • **Indicates mandatory kexts.
  • All the added kexts must exists in the EFI/OC/Kexts directory.
  • The options which have been not discussed above, that will remain untouched.
Kernel>Emulate
This section allows to spoof your CPU ID if you're using an unsupported CPU such as Intel Pentium(s) and Celeron(s). As there is no support for Alder Lake yet, CPU spoofing is needed in order to boot the system. The following changes are needed.
CPUCpuid1DataCpuid1MaskNotes
Intel Alder Lake55060A00 00000000 00000000 00000000FFFFFFFF 00000000 00000000 00000000
  • Spoof as an Intel Comet Lake CPU
Kernel>Scheme
OptionsValueNotes
FuzzyMatchYES
  • Enables checksum ignore with kernel cache instead of using latest cache available.
  • This setting allows matching the latest kernel cache with a suitable architecture when the kernel cache without suffix is unavailable, improving macOS 10.6 boot performance on several platforms.
KernelArchAuto
  • Determines Kernel Architecture.
KernelCacheAuto
  • Determines Kernel Cache.
Kernel>Quirks
QuirksValueNotes
AppleCpuPmCfgLockYES
  • Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in AppleIntelCPUPowerManage- ment.kext, commonly causing early kernel panic, when it is locked from writing.
  • Enable this quirk if you cannot disable CFG-Lock in BIOS/UEFI.
AppleXcpmCfgLockYES
  • Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in XNU kernel, commonly causing early kernel panic, when it is locked from writing (XCPM power management).
DisableIoMapperYES
  • Disables IOMapper support in XNU (VT-d), which may conflict with the firmware implementation.
  • This option is a preferred alternative to deleting DMAR ACPI table and disabling VT-d in firmware preferences, which does not break VT-d support in other systems in case they need it.
  • Enable this quirk if you cannot disable VT-d in BIOS/UEFI.
DisableLinkeditJettisonYES
  • Disables __LINKEDIT jettison code.
  • Provides more reliable performance without keepsyms=1
  • This quirk is required for macOS Big Sur.
PanicNoKextDumpYES
  • Prevent kernel from printing kext dump in the panic log preventing from observing panic details.
PowerTimeoutKernelPanicYES
  • Disables kernel panic on setPowerState timeout.
  • Fixes kernel panics related to power changes with Apple drivers in macOS Catalina, most notably with digital audio.
ProvideCurrentCpuInfoYES
  • Fixes CPU Topology
  • This quirk is required for Alder Lake CPUs.
XhciPortLimitYES
  • Enables 15 port limit patch.
  • This quirk is a temporary solution and is advised to map your USB ports during post-installation.
Note:
  • The values which have been not discussed above, that will remain disabled.
NVRAM>Add
UUIDKeyValueTypeNotes
7C436110-AB2A-4BBB-A880-FE41995C9F82boot-args
  • -v
  • alcid=1
  • agdpmod=pikera
  • debug=0x100
  • keepsyms=1
STRING
  • Adds boot args which provides several functions.
-v
  • Enables verbose mode. Helpful to track the installation progress or when booting.
alcid=xx
  • Sets Layout ID = 1 for Onboard/Built-In Audio.
agdpmod=pikera
  • Fixes Black Screen at boot for NAVI GPUs.
  • If you're using and AMD NAVI based GPU, you'll need to use this boot arg.
debug=0x100
  • This disables macOS's watchdog which helps prevents a reboot on a kernel panic.
keepsyms=1
  • This is a companion setting to debug=0x100 that tells the OS to also print the symbols on a kernel panic.
  • This can give some more helpful insight as to what's causing the panic itself.
csr-active-config
  • 00000000
DATA
  • Defines SIP type.
00000000
  • Enables SIP completely. (0x0)
  • It's advised to configure SIP via recovery using "csrutil."
  • For more information on SIP, check the SIP disabling guide.
prev-lang:kbden-US:0STRING
  • Sets Keyboard language.
PlatformInfo
Suggested SMBIOS
SMBIOSCPU
iMacPro 1,1Intel Alder Lake for i3 and i5
MacPro 7,1Intel Alder Lake for i7 and i9
DataHub
OptionValueNotes
Add this section in config.plistYESAdds DataHub field
Generic
OptionsValueNotes
Add this section in config.plistYESAdds Generic field
from SMBIOSYES
ProcessorType0
  • Sets SMBIOS Processor Type.
  • This will override your actual CPU type.
  • It's recommended to set this option to "0" to detect the original CPU by macOS instead of using SMBIOS CPU Type.
SystemMemoryStatusAuto
  • Indicates whether system memory is upgradable in PlatformFeature. This controls the visibility of the Memory tab in About This Mac.
Auto
  • Use the original PlatformFeature value.
  • It's recommended to set this option to "Auto."
Upgradable
  • Explicitly unset PT_FEATURE_HAS_SOLDERED_SYSTEM_MEMORY (0x2) in PlatformFeature.
Soldered
  • explicitly set PT_FEATURE_HAS_SOLDERED_SYSTEM_MEMORY (0x2) in PlatformFeature.
SpoofVendorYESSets SMBIOS vendor fields to Acidanthera
PlatformNVRAM
OptionValueNote
Add this section in config.plistYESAdds PlatformNVRAM field
For more information on Comet Lake config.plist, check the post linked below.
SMBIOS
OptionValueNote
Add this section in config.plistYESAdd SMBIOS field.
Installing OpenCore EFI
2. Copy the EFI from your working directory to the EFI partition of your Bootable USB Flash Drive.
Now you’ve successfully installed OpenCore, the required drivers, kexts, and config.plist and the USB Flash drive is ready to boot off your computer.
Installing Thunderbolt Card
The next step is to install Thunderbolt Card.
PCIe SlotPCIe Device
Slot 1AMD RX 5700 XT
Slot 2None
Slot 3None
Slot 41xGIGABYTE GC-Titan Ridge v2.0
Notes:
  • The Titan Ridge Card will have the THB_C Cable jumper and USB 2.0 Header connected.
  • The Titan Ridge card is flashed with NVM33 custom firmware.
UEFI Settings
SettingsValue
SATA EmulationAHCI
Network BootDisabled
Virtualization TechnologyEnabled
Legacy SupportEnabled
Secure BootDisabled
Fast BootDisabled
Once the UEFI is set up, Save & Exit Setup.
For Thunderbolt Settings, refer to the guide linked below.
Installation
Turn on your system.
6. Repeat step no. 5.
NameMacintosh HD
FormatAPFS
SchemeGUID Partition Map
12. Close Disk Utility.
This will take a couple of minutes and will restart at "Less than a minute is remaining". Upon completion, the system will automatically restart. The System will restart to complete the installation. Here ends the first phase of the installation.
The first boot may be slower as the caches are not built yet. Once the caches are built, it will boot normally.
When you're at the welcome screen, continue with the basics options such as Keyboard setup, Network, Computer Account, and Privacy settings.
Post Installation
Now, configuring the Post Installation. There is not much to do for the post-installation except configuring Thunderbolt 3 Hotplug and the boot from the system drive. Everything rest is fully functional.
As of now, the Thunderbolt already works with the exception of HotPlug. To implement the Hotplug, follow the steps below.
1. Open IOReg and find the Thunderbolt Node. For PCIe Slot #4, the address is PC00.RP21.PXSX
2. Grab the Thunderbolt Titan Ridge SSDT from 3. Adjust the address in the SSDT.
4. Save the SSDT.
For more depth information on Thunderbolt 3, refer to the guide linked below.
Boot from System Drive
This is one of the most important part as it allows to boot it using the system drive without any need for installation USB. By using this method, you’ll be easily able to install the OpenCore Boot loader on your System Drive.
3. Open your EFI Partition of your Hard Drive.
6. Copy the EFI folder from your macOS Bootable USB to your EFI Partition of your Hard Drive.
7. Download the SSDT-DTPG.
8. Copy SSDT-DTPG and Thunderbolt SSDT to ESP/EFI/OC>ACPI
9. Open your config.plist and add the SSDT entries.
10. Save your config.plist
Restart your System
After completing the post-installation, restart your System
Benchmark
Hardware Encoding and Decoding
Hello,
After following this guide, step by step, was finally able to create the opencore boot and was able to boot to USB, however, after selecting install it reads a message that OS can not be installed on this system. My specs are the exact 100% same as yours just not sure what i am missing. Shall i share config.plist?
Incomplete PR files attached.
Hardware Info: (same exact hardware as you posted within the guide)
-OpenCore as informed within the guide, zip is included.
- Used OpenCore Configurator as informed and added in the sections within the guide.
*Issue* : stuck on screen and can not get past. I have double & triple checked work. Also have read back through this thread to ensure i was following rules so i noticed i did not post zip along with pics so i have done so now.
@EliteMacx86 if you have the time, do you mind providing a bit of insight to this?
As this is an Alder Lake build, you'll need to change PCI0 to PC00. Also, you'll need to disable the SSDT-RTC0 and enable SSDT-AWAC-DISABLE.aml. In addition, SSDT-PMC.aml should not be required now.
Delete the ACPI renames as well. Lastly, the csr-active-config value is not correct. Also, MacPro7,1 is not a good choice for your hardware.
Thank you, I thought within the guide it says to have csr-active-config value at 00000000. I will make the other changes now
changes - MacPro 7,1 to iMacPro 1,1
changes - PCI0 to PC00
changes - disable the SSDT-RTC0 and enable SSDT-AWAC-DISABLE.aml
changes - remove SSDT-PMC.aml
Yes, that's right. But you have D34D34D3 4D34 right now which is invalid.
Enable XhciPortLimit quirk as well.
Got it, thank you very much. I was able to quickly make the changes, except for --> changes - PCI0 to PC00 <-- not sure where this may be. Everything else you have informed i have quickly corrected
igor333333
