ASUS PRIME Z690M-PLUS D4 - i9 12900KF - 128GB RAM - AMD RX 5700XT - Thunderbolt HotPlug - OpenCore
ASUS PRIME Z690M-PLUS D4 Build featuring Latest Intel Core i9 12900KF, Thunderbolt 3 and AMD RX 5700 XT using OpenCore. This Build is especially for Music Production offering multiple Thunderbolt ports supporting daisy chain, Cinema Display for a robust workflow. This guide can be used as a reference for any 600 series Motherboard with very few changes.
Components
| Component | Model Number |
| Motherboard | ASUS PRIME Z690M-PLUS D4 |
| Processor | Intel Core i9-12900KF |
| RAM | Patriot Viper Steel 3200MHz 1288GB DDR4 RAM (4x32GB) |
| Graphics | PowerColor AMD RX 5700XT 8GB |
| SSD | Team Force 4TB PCIe NVMe SSD |
| Audio | Realtek ALC897 |
| Display | |
| Ethernet | Intel I219-V |
| Wireless/Bluetooth | Fenvi BCM94360CD |
| Thunderbolt | GIGABYTE GC-Titan Ridge v2.0 |
Already Owned
Fractal Design Define 7XL (CC-9011078-WW)
LG 32" Full HD IPS Monitor with HDMI, and Display Port (LG 22MP58VQ-P)
Antec HCG Gold 750W Power Supply
Dell KM636 Wireless Keyboard & Mouse Combo
Comments
The Build
As the new 600 series Motherboard is out, I decided to test it and check the performance on a Hack. The idea of this build is to utilize Thunderbolt and use it for production.
Due to the easy availability of Z690 and the number of NVMe slots that were needed, the ultimate choice was ASUS Z690M-PLUS D4. It's a mATX motherboard offering support for 12th Gen. CPUs. PCIe 4.0 supports a faster data transfer rate. Along with all these, the motherboard supports 3x PCIe 4.0 NVMe and built-in WiFi.
On this Motherboard, the Audio Codec is not so great, offering ALC897. In addition, this Motherboard only offers 4xSATA 6.0Gb/s ports. An addition of 2.5Gb/s LAN would make it awesome but considering the budget, it's still a good go as these two were not the needs for this build.
Summary
| Features | Status |
| Graphics | YES |
| Built-in Audio | YES |
| DP/HDMI | YES |
| DP/HDMI Audio | YES |
| Ethernet | YES |
| WiFi/BT | YES |
| AirDrop | YES |
| Handoff | YES |
| Thunderbolt 3 | YES, with full HotPlug |
| Thunderbolt Dock | YES, with full HotPlug |
| eGPU | YES, with full HotPlug |
| Power Management | YES |
| App Store | YES |
| iMessage | YES |
| FaceTime | YES |
| iCloud | YES |
| USB 2.0, 3.0, 3.1 and USB Type-C Ports | YES |
Not working
Everything works like a charm.
Bootable Media Creation
2. Plug USB to your system.
4. Close Disk Utility.
5. Open Terminal and type:
| Directories | Description |
| Docs | Contains documentation, change log, a sample config.plist, and ACPI Samples for OpenCore. |
| IA32 | Contains OpenCore EFI, 32-bit OpenCore Boot Loader. |
| Utilities | Contains several utilities. |
| X64 | Contains OpenCore EFI, 64-bit OpenCore Boot Loader. |
Adding Required SSDTs
| SSDT Name | Notes |
| SSDT-EC-USBX |
| SSDT-RTC0 |
| SSDT-PMC |
| SSDT-PLUG-ALT |
Adding Required Drivers
| Driver Name | Required | Notes |
| OpenRuntime.efi | YES |
| OpenHfsPlus.efi | YES |
| OpenCanopy.efi | Optional |
| AudioDxe.efi | Optional |
2. From the EFI/OC directory, just keep the above drivers and delete rest of the drivers.
- All the drivers can be found at: X64/EFI/OC/Drivers
Adding Required Kexts
| Kext Name | Required | Notes |
| Lilu | YES |
| VirtualSMC | YES |
| WhateverGreen | YES |
| AppleALC | YES |
| NVMeFix | YES |
| USBInjectAll | YES |
| XHCI-unsupported | YES |
| IntelMausi | YES |
1. Download the above kexts.
Notes:
- Use the kext from RELEASE folder and RELEASE.zip file.
- Do not place unnecessary kexts here. It might prevent booting the installer.
- Only use basic kexts which is required to boot off the installer. You can install the rest required kexts at the time of post-installation.
- The VirtualSMC package includes Battery and Sensors plugins (SMCBatteryManager.kext, SMCDellSensors.kext, SMCLightSensor.kext, SMCProcessor.kext, and SMCSuperIO.kext). You do not need these kexts for booting the installer.
ACPI>Add
| SSDT Name | Notes |
| SSDT-RTC0 |
| SSDT-EC-USBX |
| SSDT-PMC |
| SSDT-PLUG-ALT |
ACPI>Patch
| Table Signature* | Find | Replace | Comment | Enabled | Notes |
| DSDT | 50454750 | 47465830 | Rename PEGP to GFX0 (Graphics) | YES |
| DSDT | 48454349 | 494D4549 | Rename HECI to IMEI (PAVP)* | YES |
| DSDT | 4D45495F | 494D4549 | Rename MEI to IMEI (PAVP)* | YES |
| DSDT | 48444153 | 48444546 | Rename HDAS to HDEF (Audio) | YES |
Booter>Quirks
| Quirks | Value | Notes |
| AvoidRunTimeDefrag | YES |
| DevirtualiseMmio | YES |
| EnableSafeModeSlide | YES |
| ProvideCustomSlide | YES |
| RebuildAppleMemoryMap | YES |
| SyncRuntimePermissions | YES |
| ProvideMaxSlide | 0 |
Note:
- The values which have been not discussed above will remain disabled.
DeviceProperties
This section is used for adding device properties. This includes PCI Devices information such as Graphics, Audio, WiFi, Ethernet and other controllers. No any changes are needed.
Kernel>Add
| Arch | BundlePath* | ExecutablePath | PlistPath | Enabled | Notes |
| Any | Lilu.kext** | Contents/MacOS/Lilu | Contents/Info.plist | YES |
| Any | VirtualSMC.kext** | Contents/MacOS/VirtualSMC | Contents/Info.plist | YES |
| Any | WhateverGreen.kext** | Contents/MacOS/WhateverGreen | Contents/Info.plist | YES |
| Any | AppleALC.kext** | Contents/MacOS/AppleALC | Contents/Info.plist | YES |
| Any | USBInjectAll.kext** | Contents/MacOS/USBInjectAll | Contents/Info.plist | YES |
| Any | XHCI-unsupported.kext** | Contents/Info.plist | YES |
| Any | IntelMausi.kext** | Contents/Info.plist | YES |
Notes:
- All the plugins must load after loading it's dependencies otherwise the kext will no longer function even when loaded in OS X/macOS.
- The mandatory kexts must be loaded in sorted order as shown in the above table.
- *Indicates BundlePath i.e. Name of the Kext
- **Indicates mandatory kexts.
- All the added kexts must exists in the EFI/OC/Kexts directory.
- The options which have been not discussed above, that will remain untouched.
This section allows to spoof your CPU ID if you're using an unsupported CPU such as Intel Pentium(s) and Celeron(s). As there is no support for Alder Lake yet, CPU spoofing is needed in order to boot the system. The following changes are needed.
| CPU | Cpuid1Data | Cpuid1Mask | Notes |
| Intel Alder Lake | 55060A00 00000000 00000000 00000000 | FFFFFFFF 00000000 00000000 00000000 |
Kernel>Scheme
| Options | Value | Notes |
| FuzzyMatch | YES |
| KernelArch | Auto |
| KernelCache | Auto |
Kernel>Quirks
| AppleCpuPmCfgLock | YES |
| AppleXcpmCfgLock | YES |
| DisableIoMapper | YES |
| DisableLinkeditJettison | YES |
| PanicNoKextDump | YES |
| PowerTimeoutKernelPanic | YES |
| ProvideCurrentCpuInfo | YES |
| XhciPortLimit | YES |
Note:
- The values which have been not discussed above, that will remain disabled.
NVRAM>Add
| UUID | Key | Value | Type | Notes |
| 7C436110-AB2A-4BBB-A880-FE41995C9F82 | boot-args |
| STRING |
agdpmod=pikera
| csr-active-config |
| DATA |
| prev-lang:kbd | en-US:0 | STRING |
PlatformInfo
Suggested SMBIOS
| SMBIOS | CPU |
| iMacPro 1,1 | Intel Alder Lake for i3 and i5 |
| MacPro 7,1 | Intel Alder Lake for i7 and i9 |
DataHub
| Option | Value | Notes |
| Add this section in config.plist | YES | Adds DataHub field |
Generic
| Add this section in config.plist | YES | Adds Generic field |
| from SMBIOS | YES | |
| ProcessorType | 0 |
| SystemMemoryStatus | Auto |
| SpoofVendor | YES | Sets SMBIOS vendor fields to Acidanthera |
PlatformNVRAM
| Option | Value | Note |
| Add this section in config.plist | YES | Adds PlatformNVRAM field |
For more information on Comet Lake config.plist, check the post linked below.
GUIDE - How to Create OpenCore Config.plist file for booting macOS on Intel Desktops
How to Create OpenCore Config.plist file for booting macOS on Intel Desktops An EliteMacx86 Exclusive Guide - This guide covers creation of config.plist for booting macOS on Intel Desktops for OpenCore as a bootloader. Overview The config.plist is a system configuration file for the...
elitemacx86.com
SMBIOS
| Add this section in config.plist | YES | Add SMBIOS field. |
Installing OpenCore EFI
2. Copy the EFI from your working directory to the EFI partition of your Bootable USB Flash Drive.
Now you’ve successfully installed OpenCore, the required drivers, kexts, and config.plist and the USB Flash drive is ready to boot off your computer.
Installing Thunderbolt Card
The next step is to install Thunderbolt Card.
| PCIe Slot | PCIe Device |
| Slot 1 | AMD RX 5700 XT |
| Slot 2 | None |
| Slot 3 | None |
| Slot 4 | 1xGIGABYTE GC-Titan Ridge v2.0 |
Notes:
- The Titan Ridge Card will have the THB_C Cable jumper and USB 2.0 Header connected.
- The Titan Ridge card is flashed with NVM33 custom firmware.
UEFI Settings
| Settings | Value |
| SATA Emulation | AHCI |
| Network Boot | Disabled |
| Virtualization Technology | Enabled |
| Legacy Support | Enabled |
| Secure Boot | Disabled |
| Fast Boot | Disabled |
Once the UEFI is set up, Save & Exit Setup.
For Thunderbolt Settings, refer to the guide linked below.
GUIDE - How to Enable ThunderBolt on macOS
How to Enable ThunderBolt 2, Thunderbolt 3 and Thunderbolt 4 on maOS [Clover/OpenCore] An EliteMacx86 Exclusive Guide - This guide covers implementation of Thunderbolt 2, Thunderbolt 3 and Thunderbolt 4 on macOS using Clover and OpenCore. Overview This guide covers the implementation of...
www.elitemacx86.com
Installation
Turn on your system.
6. Repeat step no. 5.
| Name | Macintosh HD |
| Format | APFS |
| Scheme | GUID Partition Map |
12. Close Disk Utility.
This will take a couple of minutes and will restart at "Less than a minute is remaining". Upon completion, the system will automatically restart. The System will restart to complete the installation. Here ends the first phase of the installation.
The first boot may be slower as the caches are not built yet. Once the caches are built, it will boot normally.
When you're at the welcome screen, continue with the basics options such as Keyboard setup, Network, Computer Account, and Privacy settings.
Post Installation
Now, configuring the Post Installation. There is not much to do for the post-installation except configuring Thunderbolt 3 Hotplug and the boot from the system drive. Everything rest is fully functional.
As of now, the Thunderbolt already works with the exception of HotPlug. To implement the Hotplug, follow the steps below.
1. Open IOReg and find the Thunderbolt Node. For PCIe Slot #4, the address is PC00.RP21.PXSX
2. Grab the Thunderbolt Titan Ridge SSDT from 3. Adjust the address in the SSDT.
4. Save the SSDT.
For more depth information on Thunderbolt 3, refer to the guide linked below.
GUIDE - How to Enable Thunderbolt 3 Hotplug on macOS
How to Enable Thunderbolt 3 Hotplug on macOS [Clover/OpenCore] An EliteMacx86 Exclusive Guide - This guide covers the implementation of Thunderbolt™ 3 Hotplug on macOS for single and multiple Thunderbolt 3 Cards. Overview An EliteMacx86 Exclusive Guide - In our previous post, we covered a...
elitemacx86.com
Boot from System Drive
This is one of the most important part as it allows to boot it using the system drive without any need for installation USB. By using this method, you’ll be easily able to install the OpenCore Boot loader on your System Drive.
3. Open your EFI Partition of your Hard Drive.
6. Copy the EFI folder from your macOS Bootable USB to your EFI Partition of your Hard Drive.
7. Download the SSDT-DTPG.
8. Copy SSDT-DTPG and Thunderbolt SSDT to ESP/EFI/OC>ACPI
9. Open your config.plist and add the SSDT entries.
10. Save your config.plist
Restart your System
After completing the post-installation, restart your System
Benchmark
Hardware Encoding and Decoding
