Black screen /bootloader bootlop issue when installing sonoma
Threadripper_1
Gigabyte A520m k v2
Ryzen 5 5500
Sapphire Pulse Rx 6600
hello everyone, when I press intall for hackintosh installation, verbose opens and the system restarts, and it stays on the black screen as in the attached video or throws back to the bootloader after waiting for a while.
My issue :
My efi : https://files.fm/u/gqzs796sny
Bios settings :
Iommu off
above 4g on /resizebar off (I have the same problem with npcix2000)
secure boot off
csm closed
fastboot off
My issue :
Bios settings :
Iommu off
secure boot off
csm closed
fastboot off
Is this upgrade or a clean install?
Clean install
Try a couple of NVRAM resets. Also, make sure that the GPU is installed in the X16 Slot and you're using a certified HDMI Cable. Try to plug/unplug the HDMI Cable and then check. If using DP, try the same.
Sorry for late response ı tryed nvram reset 7 8 time still same and gpu and HDMI cable is correct bec ı succesfully boot on january without any issue but that event that efi which ı used before not working ı dont know why
You can re-create the EFI. Not a big issue.
natsukiro
