SOLVED Ventura keeps rebooting to installer, even after "installed"
sweep
HP Pavilion 14-al062nr
Intel Core i5-6200u
Intel HD Graphics 520
Hello, recently I have started to work on installing macOS Ventura on an HP Pavillion 14-al062nr. I have been following the Dortania guide, and it seems to have been going well up to this point.
After installing Ventura from USB, it reboots and allows me to select the "install macos" option from the opencore boot menu. However, after selecting this option, it simply boots back to the installer, the same one mentioned previously. According to the guide, I should be seeing an apple logo with a timer at the bottom, but I don't
Please let me know if you have any ideas or ways to help.
Works now, I just messed with the config.plist and it works now.
Hello, I have the same problem, what did you do to fix it?
just disable secure boot mod from ocat or any confrigation tool that you are using
the section is located in (Misc-Security-Secure boot mod - Disable ) as shown in image i share i hope it solve your problem of loop rebooting after install . ;)
OK, its solved i follow the next guide:
Were you trying to install Sonoma or Ventura?
Help! same issue, but the fixes in both threads are not working. let me know if I need to attach my /OC folder, my phone camera isn't quite quick enough to capture the logs from the loading screen. i7-9700 +igpu, b360m Bazooka, opencore 0.9.9, macOS ventura. Apologies for the lack of details, I'm fairly new to this and having trouble finding any more information than these two threads.
should also add that 'Reset NVRam' isn't there, the enable for it isn't in config.plist and it throws an error when I add it in so I'm using CleanNVram
ploukop
