Hp Envy x360 Convertible macOS Sonoma
358
  1. Other
I am a beginner at Hackintosh/Ryzentosh.I installed macOS Sonoma on my Hp Envy X360 Convertible 15-ds0xxx AMD Ryzen 5 3500U.After installation is complete, when the initial settings screen appears, it freezes or crashes within a few seconds, then immediately restarts and returns to the initial settings screen.In this case, should I change/modify config.plist or Kext? I would be grateful if you could give me some advice.Thank you.
Sounds like low VRAM issue.
itzm3do
