hp 255 g8
Looks correct but its weird that the PNLF is not there despite being attached.
Make sure you're using the latest version of NootedRed from the forum.
And how do you know if it works or not? Can I send you the records?
Cause, the System Report does not show an active PNLF. Due to which the Brightness does not work even via the slider as mentioned by you.
xxxxxxxxxx
