How to Inject EDID [Clover/OpenCore]
An EliteMacx86 Exclusive Guide - This guide covers the implementation of EDID using Clover and OpenCore. By following this guide, you'll be able to extract the EDID using different methods and inject using Clover or OpenCore for macOS.
EDID stands for Extended Display Identification Data. The EDID contains all the information of a display in a metadata format. Some of the basic information includes display model, resolution, and refresh rate. Normally, the OS will detect the EDID automatically for the Display device connected and will include all the possible settings. However, in a few cases, the EDID may not be correct and due to this, you can have certain issues like color, sleep/wake, etc.
Note that it's generally not needed unless you have some sort of issue due to the automatic detection of EDID by OS.
STEP 1: Finding EDID
Depending on your preferences, choose one of the methods to grab EDID as described below. We recommend using the Ubuntu Method for the highest accuracy.
1. Download IOReg.
2. Open
3. You should see something similar to the screenshot attached below:
4. Find the
5. The
6. Copy the complete value and paste the copied value into any text file.
1. Download DarwinDumper
2. Extract DarwinDumper to get the DarwinDumper.app If you want, you can move it to your
3. Right-click on the
4. Select the path where you want to save the Dump. By default, the Save Path for the dump will be the location where you extract the App. To select a different location, click on
5. Click on
Once completed, you'll see Completed status just right to the dump and the result directory will be opened automatically.
6. Quit DarwinDumper.
7. Open the EDID directory from the Dump (DarwinDumper....) and you'll have three files in the directory.
8. Open
NOTE: The EDID Dump might be blank if your Graphics is not working and in that case, you'll have to use a different method to grab the EDID.
1. Boot using Ubuntu LiveUSB. Once booted, select Try Ubuntu and click on Next.
2. Install edid decode package using
3. Once the package is installed, you can display the EDID using the command
4. You can select the EDID value and copy it to any .txt file on the USB.
5. Shut Down the Ubuntu and Remove the Live USB when prompted.
1. Visit EnTech Taiwan and download the Monitor Asset Manager
2. Install MonInfo. Simply continue with the installation instructions displayed. When prompted, select
3. When the setup wizard is completed, select
4. On the left pane, you'll see a bunch of Display IDs and just below that, you'll see the Raw Data (in Hex value). The right pane contains the complete monitor info.
5. The active monitor will be selected by default. If not, select the monitor (ending in Registry-Active). Yes, that's the current active monitor. Once selected, all the monitor info will be displayed in the right pane.
6. Maximize the MonInfo in full screen and you can view the details more easily. The Raw Data is what the EDID you're looking for!
7. To copy the EDID, simply select all the values under the
8. To dump the EDID.bin, click on
NOTE: Do not dump the EDID in .hex file as it's not accurate, at least using this app.
Patching EDID
As seen before, macOS appears to ignore the checksum. However, it's good to have it calculated the right way!
macOS Catalina and Later
If you're not aware, on macOS Catalina and later, the root volume is locked and needs write access to modify any files. This is done for the sake of security, but then has increased the problems at dev's end, or simply for those who like to tinker, especially on a non-Apple computer running macOS.
1. Extract the EDID using the DarwinDump method.
2. Copy the EDID.bin file to any other directory.
3. Open the FixEDID App.
4. Click on the Open EDID binary file and select the EDID.bin.
5.
6.
7. Click on Make. FixEDID will automatically generate a new directory on the Desktop.
STEP 2: Injecting EDID
Now, as we've EDID value, we can inject it using config.plist for macOS. You can also inject it using the SSDT.
To inject the EDID, follow the steps below.
1. Find the Device Path of the GPU. The IGPU path for Intel Graphics is
3. Open your config.plist.
4. Depending on the bootloader you use, add the following properties to your config.plist under Devices>Properties (for Clover) and DeviceProperties (for OpenCore):
5. Paste the
6. Save your config.plist.
NOTE:
STEP 3: Restart your System
Do I need to inject EDID?
Generally, injecting EDID is not necessary as it is automatically detected from the connected display. However, in cases where you have some sort of issue like the EDID is not detected automatically or is wrong, then you must inject the EDID. Some displays may result in a complete blank screen unless you inject a proper EDID. In addition, there are cases, where you need to inject a modified EDID to get the display.Can I inject EDID for NVIDIA and AMD?
Yes, you can inject the EDID for NVIDIA and AMD GPUs as well.STEP 1: Finding EDID
Method #1: Using IOReg
Using this method, you can grab EDID very easily. However, its limited to macOS and you also need working Graphics with acceleration, or the EDID will not be displayed. To grab EDID using IOReg, follow the steps below:1. Download IOReg.
2. Open
IOReg and type display in the search box.3. You should see something similar to the screenshot attached below:
4. Find the
AppleDisplay which is located under the display0 node. This is where the active display is connected to the particular framebuffer. On the right pane, you'll have several properties. Look for IODisplayEDID and you should see something similar to the screenshot attached below:
5. The
IODisplayEDID is where your display EDID is located. To copy the EDID, simply click on IODisplayEDID and then double-click on the EDID Value.6. Copy the complete value and paste the copied value into any text file.
- The display node can be GFX0 or IGPU (if renamed properly).
- The EDID Dump might be blank if your Graphics is not working and in that case, you'll have to use a different method to grab the EDID.
Method 2: Using DarwinDumper
DarwinDumper is one of the tools designed to extract various information on OS X/macOS, including System Report, IOReg, BIOS dump, and several other information. Unlike IOReg, it is also limited to macOS and cross platform version do not exist. To grab EDID using DarwinDumper, follow the steps below:1. Download DarwinDumper
Applications directory.3. Right-click on the
DarwinDumper.app and click on Open.
Choose and select the directory where you want to save the dump.
5. Click on
Deselect All Dumps. By default, all dumps are selected. As you only need the EDID, simply select the EDID checkbox and click on Run. It will take a moment to prepare the dump.
EDID.bin, EDID.hex, and EDID.txt. EDID.hex is what you need. Copy EDID.hex to some other location.
8. Open
EDID.hex using any TextEditor or HexEditor tool. That's your EDID.
Method 3: Using Ubuntu
Ubuntu is more than an Operating System and what information cannot be extracted on it? Using Ubuntu, you can also get the monitor information and get the EDID. To grab EDID using Ubuntu, follow the steps below:1. Boot using Ubuntu LiveUSB. Once booted, select Try Ubuntu and click on Next.
sudo apt install edid-decode in Terminal.
xrandr --prop | edid-decode. The EDID will be displayed under edid-decode (hex)
Method #4: Using Windows
If you're not familiar with Ubuntu, and the other methods explained don't work for you, you can use Windows to extract the EDID. To grab EDID using Windows, follow the steps below:1. Visit EnTech Taiwan and download the Monitor Asset Manager
Create a desktop icon and click on Next.
Launch MonInfo and click on Finish.
Raw data section and copy it to any .txt file to an accessible location.
File>Save as. Select the desired location to save the EDID.bin and click on Save.
Patching EDID
Modifying EDID
If you're having a black screen after wake, provided that your ACPI patching is correct, modifying the EDID will probably fix your issue.1. Extract the EDID using the DarwinDump method.
5.
6.
PciRoot(0x0)/Pci(0x2,0x0).2. Mount your ESP.
| Devices | Key | Value | Type |
| Your Device Path | AAPL00,override-no-connect | Your EDID Value | DATA |
5. Paste the
EDID value that you copied previously.6. Save your config.plist.
NOTE:
- If you're using the IOReg method, you must remove < and > from the copied value from IOReg.
