GUIDE How to Inject EDID [Clover/OpenCore]
Your profile indicates that the Laptop has dGPU as well. Have you disabled it? And is IGPU present on the Laptop?
yes I added boot arg -wegnoegpu. Yes I have an iGPU 530 inside my i7-6700hq
this is my EFI, can you please spend a little time revise it? many thanks
What macOS are you using?
I was trying to install macos from windows
it's Sonoma. Is there a problem to install such late version to my old Sky lake?
Yes. That's because Sonoma has no support for SKL drivers. You'll need to run OCLP to fix it or you can use supported OS version like Monterey for a proper support.
Alisson de Santana
