GUIDE How to Inject EDID [Clover/OpenCore]
Provide complete system details along with the monitor.
Motherboard: ASUS Z-390A
CPU: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
GPU: AMD Radeon RX6600XT
Opencore Coffee Lake
Monitor1: Z-Edge U2814K 4K 27”
Monitor 2: Sceptre Z27 4K 27”
Note: This setup with AOC monitors works perfectly and gives me 4K with HiDPI. Hackintool says AOC is 7680x4320 resolution, which with HiDPI becomes exactly 4K
Boot: Opencore 0.9.6 Coffee Lake
Monitor 1: Z-Edge U2814K 4K 27”
Please Note: This setup with AOC 4k Monitors (U4008B) works perfectly with 4K and HiDPI. The resolution it reports is 2x4K => 7680x4320 which HiDPI halves
For those interested:
If your monitor is not recognized as having HiDPI in native mode, it's due to missing EDID Info that Mac looks for from the monitor. I've tried many technique to inject the correct one. My only working solution was the PAID BetterDisplay Pro ($18 in 2023) that has a section on EDID injections and allows you to inject any resolution you like.
So it does not work with Z-Edge and Sceptre?
Modifying EDID
If you're having a black screen after wake, provided that your ACPI patching is correct, modifying the EDID will probably fix your issue.
1. Extract the EDID using the DarwinDump method.
2. Copy the EDID.bin file to any other directory.
3. Open the FixEDID App.
4. Click on the Open EDID binary file and select the EDID.bin.
5.
6.
7. Click on Make. FixEDID will automatically generate a new directory on the Desktop.
Points 5 and 6 are missing ?
Reactions: HarFanG
Hello, I'm following your guide. I got my EDID but can't paste into key AAPL00,override-no-connect value. Seems it's too long
Paste the value without comma, spaces and without 0x and it works fine :)
hello, this is my EDID, after removing all comma. it's from Monitor Asset Manager. Do I have to remove anything else? As after injection I still get a black screen after verbose. Thank you
00FFFFFFFFFFFF004C834C320000000000170104952213780ACE859E5B4C942617505400000001010101010101010101010101010101DC3780A0703840403020250058C2100000190000000F0000000000000000001E82105200000000FE0053414D53554E470A2020202020000000FE00313536484C30312D3130340A2000CF
Your profile indicates that the Laptop has dGPU as well. Have you disabled it? And is IGPU present on the Laptop?
g.gott81
