Cannot fake the gpu in big sur
joe
msi x370
ryzen 5
amd
11.0.x
  2. OpenCore (Legacy)
  1. Other
Hello, I have a problem with big sur on intel i7 4770k, I would use this integrated gpu but its on VGA so it doesn't work for some reason
I have an r7 240 laying around and i though to make it work so I can try this os properly
I have followed dortania guide for faking the cpu and I compiled the asl file with my bios name in it. I left the fake id at 67 as it is the same gpu that they use in the article, they use r7 240 and they fake it to r9 390
I also have whatever green 1.5.1 version but it wont work. The config xml file in the efi folder has the key for loading the spoof gpu. I get the gpu identified at my correct resolution but it's on 8MB of vram and there is no acceleration.
I attached my efi folder in case it may be of relevance. Thank you.
  • efi.zip
    efi.zip
VGA isn't supported and it will not work. Use a digital connection like DP/HDMI. DVI to HDMI/DP can work.
Your configuration is not as per the guide so do not expect things to work. It's already explained in the main guide.
Once you have the proper EFI, update the thread and make sure to attach the new EFI.
alexito
