- Jan 30, 2023
- Gigabyte GA-Z87-DS3H
- Intel Core i5 4590 @ 3.3GHz
- Intel HD4600
- 10.13.x
- iMac
I'm looking for some ideas on what I might try next to solve a couple of issues on my Big Sur installation on a Gigabyte GA-Z87-DS3H motherboard with built-in HD4600 graphics.
I previous ran MacOS High Sierra on this rig with things working pretty well. This setup is rather old and I used the Clover Boot loader. The two items I have not been able to solve with Big Sur are Audio and Dual Monitor display.
With the Big Sur installation, I am running the latest OpenCore Boot Loader ... 0.8.8.
The same layout-id for my Realtec ALC887 audio device does not work on Big Sur. I went through all of the possible layout-ids in an attempt to see if they would work, but no luck. I am using Lilo along with AppleALC and the appropriate kexts are loaded. The IORegistry output attached does not match what I have on High Sierra, but I don't know where to look next.
I had two monitors working under High Sierra ... one is plugged into the DVI port and one is plugged into the HDMI port on the motherboard. I looked at the output of IORegistry and on the High Sierra install, I see the 3 ports for the graphics device and I get two framebuffer display devices showing. On Big Sur, I set up the framebuffer patches in my config.plist to set all of the ports and flags according to the specifications for the HD4600. However, I never get a display device for the second framebuffer to appear. BIOS settings are identical to what I had on High Sierra, and cabling is the same. The DVI port displays properly to my monitor. The HDMI port displays boot messages under OpenCore, but once the MacOS kernel boots and the Apple logo appears, only the DVI-attached monitor has an image. The HDMI port display just shows garbage/random pixels.
Thanks for any assistance/guidance you can provide.
