[Fix] USB Port Limit 10.14.4 by ©PMHeart
DSM2
EVGA SR-3 DARK
Intel Xeon W-3275M
2x AMD Radeon 6900XT
  1. iMac Pro
  2. Mac Pro
  3. Mac mini
  4. MacBook Pro
PMHeart found a way how to fix the USB Port Limit Drama with this 3 KextsToPatch Entries.
Just add them to your Config.plist and everything is great again.
All credits goes out to @PMHeart
PS: Personally I didn't check them out...
Since I don't need them all because I use a custom USB Kext on all my devices.
They work and all 3 have to be added to your Config.plist
kext     : com.apple.iokit.IOUSBHostFamily
Find     : 83FB0F0F 870B0400 00
Replace  : 83FB3F0F 870B0400 00
Name     : USB Port Limit Patch 1 ©PMHeart
kext     : com.apple.driver.usb.AppleUSBXHCI
Find     : 4183FF0F 0F839404 0000
Replace  : 4183FF3F 0F839404 0000
Name     : USB Port Limit Patch 2 ©PMHeart
Find     : 83E30FD3 E34109DF
Replace  : 83E33FD3 E34109DF
Name     : USB Port Limit Patch 3 ©PMHeart
Cheers,
DSM2
It works like a charm. Tested on macOS Mojave 10.14.4. :)
Please can you write 10.14.6 port limit patches?
Reactions: thenightflyer
Thanks, i will try and report
kocsik
