Animation and graphics freezes
So that means we're running on Mars then? You should read the link you mentioned carefully.
As per the link:
Graphics support​
Since there is no sane reason to use an IGPU-inclusive Mac model with not working IGPU, CPUFriend is generally required. IM201 vectors generally fit as they provide up to 4 GHz stepping. IPG detects the CPUs and shows their temperatures and load as well.
  • CML IGPU works fine without connectors as a video decoding accelerator for Polaris. Using CML IGPU exclusively will require manual connector patching. We did not test that thoroughly as IGPU-only configurations are prone to errors.
  • RKL IGPU is unsupported and will likely never be. Booting with RKL IGPU enabled with or without connectors results in boot failure (black screen). Can be disabled by WEG in macOS exclusively through injecting disable-gpu into an IGPU device. This can let other systems use IGPU acceleration to off-load tasks.
Read it until you get it. In case if you want to know, the link says CML IGPU works fine as headless and for display, connector patching (framebuffer patching) is required. This is absolutely normal and is applicable to most of the generations out there. Not sure why you read it as unsupported. xD
I'm sorry, I'm green in this topic.
And yes, I really threw off the wrong efi above)
No worries.
I did everything according to the guide. When installing, it freezes and gives me the attached screenshot below, as well as my efi.
EFI
Your EFI does not reflect the changes as shown in the guide. To make it clear again, all you need to do is follow the guide exactly, step by step with 0 changes at all.
I did everything as in your guide. Added the necessary cupcakes. Everything is established. Now the question is, how do I get a schedule? Animation and video playback causes lags
EFI
natsukiro
