- Sep 24, 2023
- Asus B560 -F Wifi
- i9 10900kf
- Biotech Radeon 6900XT
- iMac Pro
Make sure the prior updates are fully installed. Kexts and OC are up to date. Then delete the existing downloaded update and try again. It should be good. If the problem persists, download an offline installer as per the guide.Hi,
When I start the Sonoma Update on my Ventura Hackintosh the download stops after some seconds with the following error message:
Internet Connection is stable, so this can not be the problem.
Someone has advice what to do?
See CHAPTER 2Where to find the downloaded update?
elitemacx86.com
Great. Of course, Broadcom support is fully removed for non-soldered cards in macOS Sonoma. A guide will be there soon.Thanks, that worked.
Sonoma update is done - Fenvi 919 is gone :-(
Hi, had the same problem. Read through Chapter 2 and still can't find where to remove the downloaded update files.See CHAPTER 2
GUIDE - How to Boot macOS Installer on Desktops and Laptops using OpenCore [UEFI/Legacy] - OpenCore Install Guide
How to Boot macOS Installer on Desktops and Laptops using OpenCore [UEFI/Legacy] - OpenCore Install Guide Booting the OS X/macOS installers on a non-Apple computer can be challenging for new users. This guide is intended for those who wish to use OpenCore as a Bootloader and it covers a...elitemacx86.com
Chapter 2 is about downloading the macOS installer using several methods. You'll have to remove the downloaded update files manually.Hi, had the same problem. Read through Chapter 2 and still can't find where to remove the downloaded update files.
where can the downloaded update files be locate?Chapter 2 is about downloading the macOS installer using several methods. You'll have to remove the downloaded update files manually.
