macOS supports a wide range of Intel HD Graphics (also referred to as iGPU) but some of them might not work out of the box.
This guide will enable Full QE/CI on your Hackintosh.
This fix is for the Hackintosh users who are using Intel HD Graphics as the main GPU.
Before you start with this guide, please know something about the performance. Graphics enhance the performance and helps to work smoothly. In macOS, full acceleration requires that both Quartz Extreme and Core Image (QE/CI) should work together.
Quartz Extreme and Core Image (QE/CI) should work together to enable full acceleration on macOS’s GUI. It utilizes the complete Graphics capabilities. In case if you haven’t enabled QE/CI on your graphic card, you won’t be able to use your macOS smoothly and there would be lots of lags and artifacts, graphic related issues and poor refresh rate. Also the dock would not be transparent. Therefore it is very important to ensure that your graphic is working with full QE/CI.
Requirements:
BIOS Setting
Choosing the right config.plist file
The next step is to choose a correct config.plist according to your CPU.
You can find more information below.
www.elitemacx86.com
www.elitemacx86.com
www.elitemacx86.com
Restart your System
After performing all the above steps, restart your system in order to enable the Intel HD Graphics.
Now you should be able to get your Intel UHD Graphics 1536 MB will full QE/CI. And your Dock would be also transparent.
Problem Reporting
Details:
Credits :
Requirements:
- Intel UHD Graphics 620/630
- Original Graphics kexts in S/L/E
- macOS Sierra 10.12.6 or later
BIOS Setting
- The very first step is to setup your BIOS. This guide will only include settings for Intel HD users.
- To access your BIOS/UEFI, press and hold Delete key on your Keyboard. The key maybe different in your case. Refer to your Motherboard Guide/Manual.
- Set Initial Display Output to IGFX
- Set Internal Graphics to Auto/Enabled
- Set DVMT Pre-Allocated to 64MB
- Set DVMT Total Gfx Memory to 256/128MB
- Save & Exit Setup.
GUIDE - How to Boot macOS Installer on Laptops using Clover (UEFI/Legacy)
Booting macOS installer on laptops can be a challenge for the new users. This guide covers a complete step to boot the macOS installer on your Laptop using Clover bootloader. Those who are not using Clover, can update their configuration for clover and continue to use it. Clover is one of the...
www.elitemacx86.com
- For Kaby Lake-R and Whiskey Lake use, "config_HD615_620_630_640_650.plist"
- For Coffee Lake, use "config_UHD630.plist"
- On some Laptops, after fixing the Graphics, you may result in a black screen. For more information, check the backlight guide here:
GUIDE - How to Enable Backlight Control on Laptops [Clover/OpenCore]
How to Enable Backlight Control on Laptops [Clover/OpenCore] This guide describes the implementation of backlight control on Laptops and AIO using Clover and OpenCore bootloader. By following this guide, you'll be able to enable backlight control on your Laptop and AIO. In addition, this will...
www.elitemacx86.com
- For Whiskey Lake, use the guide below:
GUIDE - Intel UHD Graphics 620 (Whiskey Lake) on Laptop [Clover/OpenCore]
Fix Intel UHD Graphics 620 (Whiskey Lake) on Laptop An EliteMacx86 Exclusive Guide - This guide covers fixing of Intel UHD Graphics 620 (Whiskey Lake) on Laptop. By following this guide, you'll be able to achieve full QE/CI on your Hackintosh. Overview macOS supports a wide range of Intel HD...
www.elitemacx86.com
Restart your System
Problem Reporting
Details:
- Intel UHD Graphics model
- macOS version
- Copy of IOReg
- DPCIManager/Status
- About This Mac
- System Information/Graphics/Displays
- Compress EFI/Clover, exclude the themes folder. Do not include complete EFI folder.
Credits :
