- Jun 10, 2023
- Zephyrus G14 GA401QH
- AMD Ryzen 7 5800HS
- Radeon Vega 8
Start here:bro can you provide the efi file I see our devices are the same
elitemacx86.com
i have problem in config.plist, can you help me, don't know what should i modify in this file.Start here:
GUIDE - How to Boot macOS Installer on Desktops and Laptops using OpenCore [UEFI/Legacy] - OpenCore Install Guide
How to Boot macOS Installer on Desktops and Laptops using OpenCore [UEFI/Legacy] - OpenCore Install Guide Booting the OS X/macOS installers on a non-Apple computer can be challenging for new users. This guide is intended for those who wish to use OpenCore as a Bootloader and it covers a...elitemacx86.com
What problem?i have problem in config.plist, can you help me, don't know what should i modify in this file.
It seems like all the solutions are on this website but I'm still confused about how to use themWhat problem?
What problem do I get stuck on is the initial installation part, my keyboard works and the mouse does the same and soon the system suddenly crashes and freezesWhat problem?
Provide the EFI you're using to boot the system.What problem do I get stuck on is the initial installation part, my keyboard works and the mouse does the same and soon the system suddenly crashes and freezes
Hello, I have successfully installed macOS Ventura on my laptop, but I am facing some issues. The problem is related to CPU idle usage. When I open the system monitoring in macOS, the CPU idle percentage averages around 95%. This causes my laptop to heat up. In the macOS system, my CPU is detected as Intel Xeon W, and the iGPU is recognized as 512 MB. The second issue is with the trackpad. Sometimes the screen and mouse freeze.Provide the EFI you're using to boot the system.
Please create a separate thread to look down into the issues you have.Hello, I have successfully installed macOS Ventura on my laptop, but I am facing some issues. The problem is related to CPU idle usage. When I open the system monitoring in macOS, the CPU idle percentage averages around 95%. This causes my laptop to heat up. In the macOS system, my CPU is detected as Intel Xeon W, and the iGPU is recognized as 512 MB. The second issue is with the trackpad. Sometimes the screen and mouse freeze.
