AsusSMC on Ventura
How do I make an .asl file instead of a bulky 300KB .iasl file? I'm gonna patch the SSDT manually.
You'll need to compile.
Thanks, I will try. Btw is it possible to remove all OpenCore injections to Windows and Linux? My Fn hotkeys don't work on Windows with OpenCore. I just want OpenCore as a bootloader. Thanks.
Which one, can you give me the link?
Is there another way beside using non-official OpenCore?
Unfortunately, no. Even if you use If (_OSI ("Darwin")) to your DSDT/SSDT, OpenCore will still apply Quirks, SMBIOS.
Thanks, it works fine. However, how to use ACPIDebug? It doesn't work.
jkzql77089
