Installing OpenCore to Bootable USB
After validating the config.plist, all you need to do is install OpenCore to Bootable USB. To install OpenCore, follow the steps below.
Hi,
Where can I find those steps? I'm stuck at this step right now.
Hi,
The steps will be added soon. For now, you need to copy the EFI to your target ESP.
Hello.
Where can I get SSDT-CPU-PM.aml for Ivy Bridge? There is none in Downloads section.
Hello.
For Ivy Bridge and older, you'll need to create the CPU-PM SSDT using ssdtPRGen script from PikeRAlpha
Selecting a config.plist File
OpenCore comes with default config.plist file. This config.plist cannot be used to boot most of the systems. You'll need to configure the config.plist according to your hardware, mainly the Quirks. Each System has a different set of Quirks which is required for booting. Therefore knowing your hardware is very important. In addition, you may need to configure Graphics and other PCIe devices in order to boot.
We've already created a separate thread on configuring your config.plist to boot the installer. Depending on your hardware, configure the config.plist according to the guide. Depending on the Platform and CPU you have, select the appropriate config.plist building guide.
Intel Desktops
CPU Code NameGuide Link
Penryn
Lynfield
Sandy Bridge
Ivy Bridge
Haswell
Broadwell
Skylake
Kaby Lake
Coffee Lake
Comet Lake
Rocket Lake
Alder Lake
NOTE:
  • Intel NUC and a few AIO use Mobile CPUs. For all such hardware, it is advised to use the config.plist from Intel Laptops section.
Intel Laptops
Penryn
Lynfield
Sandy Bridge
Ivy Bridge
Haswell
Broadwell
Skylake
Kaby Lake
Coffee Lake
Comet Lake
Rocket Lake
Alder Lake
Intel HEDT
Penryn
Lynfield
Sandy Bridge
Ivy Bridge
Haswell
Broadwell
Skylake
Kaby Lake
Coffee Lake
Comet Lake
Rocket Lake
Alder Lake
AMD Desktops
Hi, is it possible to have the "Guide Link" for Kaby Lake processor (laptop) ?
Thank you mate
Thank you mate
It's already covered.
Thank you!
I set up de config.plist as indicated, but when i try to restart my laptop from the USB support, this is what I obtained.
Can you understand, from this two screen, where is the problem?
What macOS version are you trying to boot?
Also, have you created the Bootable USB?
i'm triyng to install "latest version".
I prepared the USB with rufus as indicated in page 1, but right now i'm reading here:
and there seems to be some information missing.
Do I have to do any intermediate steps?
I formatted the USB with rufus:
-not bootable
-fat32
etc etc
Set the config.plist
copied the kexts and all
What is missing?
-not bootable
-fat32
etc etc
What is missing?
nesmirt
