To remove the kexts, simply move the kexts to Trash and empty the Trash.Okay thanks. I am sorry to bother you so much, could you tell how do I do that . I am not able to view the primary drive where macos is installed under devices. Any guide so that I can follow it to do what you have advised. Thanks
If you're unable to find the system volume, try the steps below.
Finder>Preferences
Select Hard Disks and Connected Servers and the drive should appear on your Desktop.
