Hi and sorry I will put the PR files later. By boot I mean reboot or after system booted.
Incomplete PR files attached. EFI folder and Kextcache output is missing.Here they are ! Thanks
You did NOT followed the guide. The guide mentions to implement SSDT for Hotplug function. Note that without SSDT, you'll always need to plug the target TB Device and restart your system to make it working. Moreover, you're not using the SSDT which is described in the guide.
