Help please
dely
AMD x570 master
amd 95900x 12 cores
Nvidia 980ti
  2. OpenCore (UEFI)
  2. iMac Pro
  3. Mac Pro
I have built my pc with amd ryzen 95900x 12 cores. Motherboard gigabytes x570 aours master, graphics card Nvidia 980ti. My questions is will i be able to install macOS if not what i have to changes or buy
It's compatible. Max you can install is High Sierra due to GPU limitation.
Thanks a lot i understand i have to upgrade my GPU
Hi what kind of GPU it's really supported
Yes, to a compatible one.
Now, as of latest macOS Monterey, only AMD GPUs are supported. It also depends on your use. What work do you have?
sabbianera
