AMD Hardware check HELP PLEASE!!:(
pawan_99cx
hp Laptop amd ryzen 3 7320U
ryzen 3 7320U
amd radeon 610
  2. OpenCore (Legacy)
This is a desktop :
AMD Ryzen 3700x
GTX 1060 3GB
16 RAM
And i also have this can you please suggest :
Both systems are supported. For the Desktop, you'll have to use OCLP to patch the Graphics
I just created an EFI from your videos amd many other i watched every time i boot i have some errors (ST.GV wake faliure ,e00or) etc. can you help me with this i attached my efi folder here PLEASE ! :(
this is my 5th time i tried but same issues i dont have the log files.
this is for a Laptop HP 25 Fc0xxx series
AMD 7320U
radeon 610m
P.S can you help me to boot atleast all the other kexts i install later this is clean EFI just like i watch this video.(ALL KEXTS And OTHER Files are up to date.)
Creating OpenCore EFI for AMD Laptops using Windows, Linux or macOS | Hackintosh | Step By Step​
  • EFI.zip
    EFI.zip
AMD 7320U
radeon 610m
Your configuration is not as per the guide. Pay attention to the guide.
voidguy
