Anything else I need to provide?
Here are a few issues.
- Remove AHCI_Intel_Generic_SATA.kext and macUSPCIO_I801.kext entry and also from OC/Kexts directory.
- Enable ExtendBTFeatureFlags in the Kernel>Quirks section.
- Set Target to 3 in Misc>Debug section.
- Remove vsmcgen=1, -mausiwol from boot-args.
- MacPro7,1 is a poor choice for your hardware. If you don't want to use IGPU, switch to iMacPro1,1. Read SMBIOS Guide.
- Remove HfsPlus.efi and use OpenHfsPlus.efi.
Once you're done with the changes, save your config.plist.
The USBMap.kext is old and is not valid. The BT is not set to Internal and you're using MacPro7,1 SMBIOS yet having iMac18,3 in the USBMap kext. This issue was already outlined in the USB Mapping Guide.
Also, for the meantime, remove NVMeFix.kext.
Restart the system and reset NVRAM twice. Attach the new PR files.
