How should I re-install macOS on the same PC
huijkkkk97
ASRock H97 Killer
Intel Core i7 4790
AMD Radeon RX Vega 56
10.13.x
Basically my macOS installation sort of broke, the boot entry disappeared and when I boot from the USB drive none of my settings are saved (kexts aren't recognized so for example wifi doesn't work). For more information, you can see the other thread I made (TLDR; it seems like it's pretty much impossible to fix).
My current OpenCore version is v0.8.1 (June 2022). I have no idea how much things have change since then and what I'd need to edit to install macOS with the latest files, kexts, OpenCore files etc. Any help to guide me would be very appreciated, PR files attached.
Sorry, the problem is I don't know how to make an OpenCore installation following my previous settings.
You'll need to create OpenCore EFI and then only you can install it.
nnaa
