How to install MacOS on B760M system?
The EFI you have attached is not build as per the guide linked above.
Start again from scratch:
I finished it and created an efi but I can't upload it here because the file is large.
I get this error and the pc restarts
Your configuration is still not as per the guide.
- Enable DeVirtualiseMmio
- Enable RebuildAppleMemoryMap and disable EnableWriteUnprotector
- Enable SyncRuntimePermissions
- AppleCpuPmCfgLock and AppleXcpmCfgLock are missing. Enable them.
- ProvideCurrentCpuInfo is missing. You must enable it.
- Enable XhciPortLimit
- Add agdpmod=pikera in boot args.
- Disable LoadEarly in Drivers.
You should not add hundreds of kexts. Just the basic ones. The rest can be added at the time of post installation.
Not sure why so many things are still missing when you actually followed the video guide. Seems like you skipped the guide.
Zementos
